Need to have a 2.5g setting and keep my main at 5g on G36
  • August 22, 2024
  • 67 views
How can I run a 2.5k setting on my guest network to hook up my home security cameras and keep the main setting at 5k on my G36?
Best answer by Netopia
You can enable 2.4 GHz Guest Wi-Fi network and disable 2.4 GHz Wi-Fi on your main network.  Keep in the devices on the main network cannot communicate with the devices on the Guest network.
If you want them to talk to each other, make sure the 2.4 GHz and 5 GHz SSID names are different and you can connect the home security to the main 2.4 GHz SSID and other devices to main 5GHz SSID.
Guest Wi-Fi Network Setup
https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/G34-G36-Customize-Guest-Wi-Fi-Network
Primary Wi-Fi Network Setup
https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/G34-G36-Changing-the-Wi-Fi-Name-and-Password
Click the Disable when you get to this screen.
Forum|alt.badge.img+30
  • Rockstar!
  • 274 replies
  • August 26, 2024
