setup for surfboard ax3000 G34
  • July 25, 2024
  • 215 views
how to setup my new arris G34 on my pc
Do you see the network name on PC under wifi connection. You can check for the default wifi credentials on the modem label underneath the modem to connect with your devices.
http://arris.force.com/consumers/articles/General_FAQs/G34-G36-Retrieve-Wi-Fi-Password
