I keep having an issue with my WD MyBook Live being seen/accessible on my LG WebTV within the Photo and Video display area of the TV.
I do notice that when the G36 is rebooting while I have the Photo and Video display up on the TV the WD MyBook live will display on the TV and I can access it for a short period of time, however it will then disappear and reappear again until the G36 has completed its reboot process.
It seems to me that there is likely a setting of some kind that is causing this behavior to occur. I have played around with the settings and reset the unit several times, but I cannot track down the relevant settings and would appreciate help on what the likely cause is?
Also to note, there was one time a several months back that the WD MyBook Live showed up for about 1-month without interruption before all together disappearing again, (I have no idea what cause this change either way.)
My connection plan uses Xfinity high-speed into my G36, the WD MyBook is connected to a G36 port by a cat-8 cable, another cat-8 runs onto a TrendNET 8-port switch within another room, the LG WebTV also connects to this same switch using a cat-8.
The WD MyBook Live is using Twonky software (an older version of it) with a 4Tb HDD. I can connect to it fine on another LG Smart TV in the living-room that uses a cat-8 connection to the G36; also I can connect to is from two different computers located in other rooms as a network location using cat-8 connections through the same TrendNET 8-port switch that the LG WebTV is connected to.
My G36 firmware ver. is: 01.04.028.01.01.NCS
