zoom and FaceTime freeze on G36
  • November 26, 2024
  • 14 views
just set up my G36 surfboard and started having problems with my screen freezing on Zoom and FaceTime calls.   I never had this problem before with my 10 yr old modem/router.   Is this happening because I set up something wrong?  did I miss something in the setup?
thankful for any assistance
  • 2292 replies
  • November 26, 2024
  1. what device is having issue?
  2. is it connected to the 2.4ghz band or the 5ghz? Or wired?
  3. what speeds do you pay for?
  4. are you getting those speeds (test a wired device)?
