How to wire and configure wired backhaul satellite
  • October 30, 2022
  • 180 views
I would like to try ethernet wiring my AX600 satellite. What port do I use on the satellite device and do I need to set it up or will it realize that it is in ethernet?  If I need to set it up, how?  I tried plugging it in to an ethernet cable and it seems to stay on the wireless backhaul.  How do I check the backhaul connection?
On my W31 (when I was using it), I simply hardwired it in and waited and it and the hardwired backhaul automatically switched. Not sure on that specific device.
Maybe @SURFboard_Moderator would know
  • 2275 replies
  • November 4, 2022
Hello bprazen
What Plemans said is accurate, let us know if you still face issues with this.
nothing is worse than when a technology company has garbage software combined with the hubris that its users couldnt possibly know how to configure the equipment.  If I knew the ecosystem had so little control or even useful feedback, i would have never spent my money.
anyway, how does one disable the wireless backhaul so the garbage app doesnt report that the backhaul is low over a wired gigabit connection?  Just plug it in is not a satisfactory answer
