Connecting Switch to AX11000 (W31)
  • July 8, 2022
  • 81 views
I need to know if I can hook up a Netgear MS108UP (or other  Multi-Gig model) switch to the W31 router. I have 8 wired devices in addition to Wi-Fi devices I need to provide Internet access to.
Can’t seem to get a straight answer from any Tech Support [sic] so far, and the Internet searches just provide click bait and junk.
The W31 is connected (or will be) to an S33 Modem.
Thanks
You should be able to without issues. I’ve connected several different unmanaged and even 1 manage switch to my W31 and it worked fine. Of course the W31 isn’t multigig so you’ll only get gigabit speeds.
  • 2275 replies
  • July 8, 2022
