IS my W31 Compatible with W21
  • 1 June 2022
  • 128 views
Userlevel 4
Hello Community, i do have an dual pack W31 installed on my house, i wanted to add another mesh to expand the coverage but find out that the W31 goes a bit out of my budget, i saw the W21 in a lower price, will be this one compatible with my setup?
Best answer by SURFboard Support 16 June 2022, 01:27
Userlevel 3
Badge +15
The W21 cannot be installed in the network with W30 or W31 mAX.  You can mix only W30 or W31 between each other, and also have an maximum of 3 devices *(Main router + 2 Satellites)
