Have a Arris T25 cable modem with Xfinity 600mbps Internet/Voice plan. I have a Netgear 6400v2 ac1750 router and everything runs great. I want to replace the Netgear router with a mesh W121 MAX ax6600 (P/N WR00ZAE21DB) which I have two units as one will be a satellite. I run the Surfboard Central App and follow directions (power down modem and router, modem cable to WAN of W21...) and go through the setup process fine until I get to end where it wants me to connect to newly created SSID which I called (Buddie’s) with my new password which I entered 100% correct. Can’t connect to the WIFI and am thrown to the Xfinity activation screen. W21 router blinks green and white at this time and when I checked Xfinity app to activate T25 modem it says I do not have an Internet plan when I do (Message from Xfinity app: (“You need xfinity internet to continue” exit activation). I did a chat with Xfinity and had them activate the modem but still couldn’t connect W21. I tried this with both w21 units with the same result. W21 never turns blue just mostly blinks green and white. Error codes from app are 0000-1303 and 0003-1003. Tried 2 different ethernet cables from modem to WAN of router (they both work fine with Netgear router). Any ideas? I’ve tried around 10X to connect through SB app. Any help would be much appreciated.
Have no internet when setting up W121 ax6600 router connected toT25 modem
Best answer by rays787
SURFboard Moderator - WIFI Warriors Thank you so much for your help.
Got it to work without calling Xfinity Support.
Instead of unplugging the T25 modem to reset I went through the Xfinity App and re-did the Provision/Activation.
- I turned OFF the Netgear router and unplugged the ethernet cable going to PC and plugged into LAN of W21 router. (So LAN of W21 to PC ethernet plug)
- I moved WAN from the Netgear to the WAN of the W21(Yellow) coming from the T25. (So one of the ethernet plugs of T25 to W21 WAN)
- Turned ON W21 router.
- In the Xfinity App went to Services/Activate more devices/Your Equipment and did the modem/router setup again.
Internet came on PC after Power, US/DS, Online and Tel 1 were all solid ON. (I have one phone line). Still had to reset W21 router once or twice but it finally connected.
