SURFboard W21 mesh router- enabling 2.4 GHz
  • July 10, 2024
  • 343 views
How do I enable only 2.4 GHz on my SURFboard W21 mesh router, I’m trying to install my Arlo doorbell chime. And it needs to install on 2.4 GHz.  Thank you for your help!
On the home screen of the surfboard central app under network setting you can see the following option
Main networks
Guest networks
Extended wifi settings
Select Extended wifi setting to disable the band steering option then
select Main network and there you can see Band steering option again disable that too then you can see both 2.4 and 5G network on the app.
Main networks
Guest networks
  • January 17, 2025
Main networks
Guest networks
I tried this and am not seeing separate networks. I’m trying to install a smart light bulb and I cannot get it nor my phone to connect to 2.4ghz.
Main networks
Guest networks
Could you let us know the product model number to assist you further?
  • January 18, 2025
Main networks
Guest networks
I’ve got an S33 modem, W21 main router, and 2 W21s as satellites.
Thank you for the reply!
When you initially set up the MAx W21 main router, you would have created a Wi-Fi name and password, with a single SSID combining both the 2.4GHz and 5GHz bands.
But unfortunately the MAx W21 do not have an option to separate the bands, but the devices have capability to choose the appropriate Wi-Fi band when connecting.
