Add satellite W133 with W161
  • March 5, 2024
  • 78 views
I have W161
SURFboard mAX. Can I add a second one W133 satellite?
W161 is a device that comes with the main router and satellite so to this particular model you wont be able to connect any separate satellite or adding satellite is not possible and there is no option for that.
