orbi wifi mesh system compatibility
  • August 18, 2024
  • 71 views
How do I switch my Arris modem to/from Bridge/AP?
In this case to assist you further could you please help me with your modem model number. To get the modem work on the Wi-Fi mode  by disabling bridge mode you can just perform hard reset on the modem then it will go to the default setup.  But after resetting the modem will go to default setup any custom settings will be removed so use the default network name and password to connect to your network.
