SB6141 does NOT have reset button on web screen
  • April 25, 2024
  • 100 views
The manual says that there should be a reset button on the Configuration screen on the web interface, but that button isn’t there.  Ideas please?  Thank you!!
SB6141 is just a cable modem so you can see the ( restore all default option ) on the modem GUI when you connect device like laptop or computer to the modem LAN port directly without coax cable connected to the modem. So please give it a try to perform reset on it.
http://arris.force.com/consumers/articles/General_FAQs/SB6141-Factory-Reset
