Shaw Direct Receiver
  • 2 January 2023
  • 19 views
I have an Arris DSR 830 (Shaw Direct) receiver that I inadvertantly plugged the wrong power supply cord into. Does anyone know if there are any fuses inside that can be replaced and if so, how do I open the case without breaking it.
Many Thanks!
Userlevel 6
Badge +40
“wrong power supply”
You can use different power supplies provided they have the exact same voltage and polarity.
did you try plugging the correct one in and trying it?
No I wasn’t that lucky! It popped as soon as I plugged in the wrong power cord. The Arris unit uses a 12 v supply, and the one I inadvertantly plugged in was for my Wingegard unit which was 48v.
