Upgrading my speed
  • May 31, 2022
  • 153 views
TechRep
Cable Modem Commandos
Forum|alt.badge.img+9
I want to upgrade my speed plan to 1 Gbps, it’s been a while since I’m using this modem and I could not find any information about the speed
Best answer by Where the Wild Pings Are
I would recommend checking with your provider to see what modems they have rated for their network for that speed tier.
The S33 is a good modem and most ISP’s should allow that on their Gig plans. But if you are looking into upgrading your Wi-Fi too, you may want to look into the G36, or adding a mAX mesh system to your network. Upgrading your modem for the Gig plan is a must, but you also want to make sure that your router is not bottlenecking all of that speed. 🚀
  • Cable Modem Commandos
  • May 31, 2022
Hello,
You must be looking forwatd for an Modem upgrade, because the SB6141 is not supported to handle Gigabit connections.
The devices that are compatible with this speed will be S33,
Hope this informations is usefull for you
Siuu1994
