Your modems, and pretty much every other modem on the planet are designed with no fans. As a result when you get above a very moderate speed of 20MB per second your modems start to overheat and then crash once they reach around 100 degrees. Extremely preventable problems if you would just install a fan, but for some odd reason no manufacturer does. And as a result every single modem from every company has this issue. Just install a fan, and it will fix it.
