S33 Firmware
What version do I have? The info page shows "NA". How do I perform an update?
Firmware depends on the ISP as all certify different versions for their service. so you won’t find a list of what is current. And the firmware is part of the provisioning from the ISP. So if its working, it should be fine.
  • Button Mashers
  • 19 replies
  • February 5, 2024
Navigate a web browser to the 192.168.100.1 IP address. Click the “Device Status” button located immediately below the password entry text box. This should show you the device specification and Firmware Version.
Hope this helps.
  • February 6, 2024
Thanks sjtnet.
Is there a way to see if I have an update? And how?
  • 2268 replies
  • February 6, 2024
