New SB6183 with Xfinity wi-fi. After instal, and several resstarts by me and Comcast, the top and bottom lights are white, not green. The system restarts on its own periodically, sometimes repeatedly. Can you tell me if the lights are a concern?
Top and bottom lights
The top/bottom light should only turn green according to the manual. Only the 2 middle led’s on it can be green or blue.
do you have a screen snip of the cable connections page? (shows upstream/downstream info)
And the event logs? Those help check the connection
