unable to connect sb6183 to cox to activate
  • August 19, 2024
  • 92 views
Sb6183 unable to connect to activate
SB6183 is not listed on the cox compatible list so this model is not compatible with COX service and that is why your modem is not getting activated. Please do check the compatibility list and get the device compatible with your ISP.
https://www.cox.com/residential/support/cox-certified-cable-modems.html​
