I’m trying to set up my surfboard Model: SB8200 and it’s asking for SSID and password provided on device label and I don’t see this info on the label. Please help. I’m getting very frustrated. There was no QR code either.
wifi name and password for sb8200
There is two ethernet ports on SB8200. But you can access only one port at the same time, because both ports are assigned under same IP address.
If you wish to use both ports at the same time, I suggest you to contact your internet service provider to activate the second port with different IP address.
