SBG10 need to do port forwarding
  • August 17, 2023
  • 44 views
I am needing to port forward my router but its only letting me do certain ports and not others
Hello cshgwt03
                            Since  you can able to do port forwarding for few ports that indicated the modem settings are fine to accept port forwarding but certain ports are not working we would suggest you to check the port number whether it is closed or open in port checker site and also just confirm whether their is any other port number available for that particular device with the respective device manufacturer.
Hello cshgwt03
