Changing upstream frequency range 5/42 to 5/65
  • June 1, 2023
  • 41 views
I cannot connect to the internet because the upstream frequency range. Arris range is 5/42 but it  must be 5/65 in Turkiye.  Is anyone else can change the  frequency with backgruund software.
Arris SBG7400AC2 Docsis 3.0
You can’t. The firmware is part of the provisioning from the ISP. Your ISP can contact arris to get newer firmware but they rarely will do that as they have to certify it then.
  • June 2, 2023
