How can I increase the Wi-Fi speed to my devices from the SBG7400AC2 unit? Connection speed via ethernet is 277 mbps, when testing using WI-FI 62 mbps. Thank you
View originalHow can I increase the Wi-Fi speed to my devices from the SBG7400AC2 unit? Connection speed via ethernet is 277 mbps, when testing using WI-FI 62 mbps. Thank you
View originalI guess those are some items I need to keep track of. I am pretty sure I was using the 2.4ghz, just realized there is a 5ghz. and was using my cell phone and was right in front of the mode/router.
I was contemplating putting the SBG7400AC2 in Bridged Mode and getting a separate WIFI 6 router. Do you think that will help with speed and range?
Thank you
