2.4 ghz issues
  • November 29, 2022
  • 9 replies
  • 101 views
When I try to connect a 2.4 ghz device (smart plug, etc) I either get an incorrect password when trying to connect or it gets connected and then drops.  I know the password is correct.
  • 2274 replies
  • December 1, 2022
Are you using any special characters/spaces in the ssid or password? I’ve seen a lot of iot devices have issues with those
  • December 1, 2022
No
  • 2274 replies
  • December 1, 2022
How many smart devices are you using?
  • December 1, 2022
The same amount I had when I was using the Xfinity modem. About 12
  • 2274 replies
  • December 1, 2022
have you tried changing wifi channels?
  • December 1, 2022
What channels
  • 2274 replies
  • December 1, 2022
the 2.4ghz channels. I’d recommend switching between 1-6-11
  • December 12, 2022
on my phone it say that I need to change my Cell Phone from 5.0 to 2.4GHZ on to let it pair. I only have 4 smart plugs .
Forum|alt.badge.img+30
  • Rockstar!
  • 273 replies
  • December 22, 2022
I’ve heard about phones having to connect to the 2.4 GHz in order to connect iOT devices that are only compatible 2.4 GHz.  I have a few iOT devices but I did not need to connect my phone to 2.4GHz.
