How do I find my network path?
There is no option to find the network path on your modem settings SBG8300. But you can find whether all your devices are connected under same IP by checking for the details of connected device on the modem interface.
I figured it out. Thanks for responding
Yes, I agree with your answer. Thank you for responding to the question. I found out when I called surfboard support.
