As with other posts, I am reporting the same now. I’ve had the modem working fine for almost 3 years and suddenly, it stopped working correctly. As I am technical, I looked at everything and noticed it was no longer receiving a WAN IP, therefore, either the DHCP functionality on the modem is failing or DHCP server at XFinitity is having issues. Talking to Xfinity support is a waste of time because they are Tier 1 ppl and only run Layer 1 tests.
If I reboot it, it sometimes works, sometimes not. When it does work, I may be good for less than 24 hrs before it starts acting up again.
I almost feel like this is some sort of scam to get people to rent their modems.
Is there any troubleshooting I could do regarding the DHCP issue? Packet captures?
