I have recently started having issues from my recently purchased ARRIS SBG8300 Cable Modem. When I had it set up with my ISP, it performed fantastic; Stable, reliable speeds, with little to no issues, all the sort, however, suddenly, when I went to bed, after about a week of it working perfectly, it all stopped working. Looking at the app and IP address, nothing seems out of the ordinary, apart from my Power Level for my Upstream being a few units below the specs specified on the website and the WAN saying “No Internet”. I’ve tried all the usual troubleshoots: Power cycling multiple times, factory resetting multiple times, checking the coax, having a technician look at it all and check the lines on another modem, and everything seemed fine. The only apparent issue I can see on the router is that, while the WiFi light is static green while connected, the internet light keeps going through the blue Downstream and Upstream indicators, blinking green for a little bit, and doing it all over again. I can still communicate to it via the app and IP address, like changing the names and passwords of the WiFi, but I just have no internet. Any help will be appreciated, I’m at a loss for what to do.
SBG8300 stuck in a bootup loop on the internet LED.
I’ve had to rent a modem to prove it wasn’t my modem. And I’ve also seen it be the modem. You might need to either check with another modem or rent one to see if it works if the ISP isn’t willing to recheck the line.
