I have a Loran device which uses a power injector to supply POE.
When I hook up the input lan cable to the injector (The mostly non-powered side) and have the other end directly in the gateway/modem (just called gateway after this) I don’t get a connection. The lights by the ports don’t light up and my device is not connected according to the UI
However, if I use the same cable and go to a switch first, it works just fine. The lights light up and my device shows connected.
Do I need a “crossover” cable in this application ? (one where the wires have switched positions relative to the jack on opposite ends)
Thanks
