Unable to connect Samsung phone and tablet with SVG2482AC
Keep getting an incorrect error message trying to connect new Samsung phone. Was able to connect a new tablet. All other devices are connected. Comcast and Samsung were no help. Any suggestions?
Since you are not able to connect with Wi-Fi on your Samsung phone and tablet with default Wi-Fi password, I suggest you to factory reset the modem and try to connect it again.
Let me share you the link to perform a factory reset for your reference:
http://arris.force.com/consumers/articles/General_FAQs/SVG2482AC-Factory-Reset
  • 2266 replies
  • January 12, 2024
what error do you get?
Are you using wpa2?
Any special characters/spaces used in the ssid/password? It shouldn’t cause issues but I’ve seen a few devices that do have issues
  • January 12, 2024
Thanks for responding.
Error message is “incorrect password”.
Yes, using wpa2.
Tablet did connect. Phone did not.
Six other devices are connected.
Password is consists of only capital letters and numbers.
Any suggestions would be appreciated.
  • 2266 replies
  • January 12, 2024
Any spaces?
If you change the ssid/password, does the tablet/phone connect?
  • January 12, 2024
No spaces.
Have not tried changing password. Don’t want to have to login the already connected devices
  • 2266 replies
  • January 13, 2024
I’d start with trying different ssids and if that doesn’t help, then try the factory reset.
Hope you were able to connect to your Samsung phone after trying on the Reset.
Were you able to succeed in connecting to the Samsung phone by changing the Wi-Fi name and pasword?
