Arris tm722g speed needed
  • March 21, 2023
  • 47 views
Hi,
I can’t find the specs for my Arris tm722g modem. I have a 10/100/1000 ethernet port on my computer, a 15 Mbps internet connection (through the phone/cable company), so I wonder if the TM722G is fast enough to take advantage of the 10/100/1000 ethernet port.
My question comes from the fact that I notice some lags when streaming 4k videos. Computer is currently connected via LAN/ethernet.
Thanks,
Hello patrouille123,
Basically TM722G  is a cable modem, sorry for the inconvenience that Arris doesn't support this modem .
Checking on the speed it should be 20mbps is required for 4k speeds.
Hope this information helps.
