modem for optimum
  • December 4, 2023
  • 121 views
What modems works with optimum? I have internet, telephone and cable with optimum
TM3402 (Docsis 3.1)  and  TM1602G ( Docsis 3.0) are the voice cable modem compatible with optimum but technical support will not be provided by Arris since these are the model manufactured for the Internet service provider so you need to contact optimum for any technical support.
