G20 - Slow speed internet connection
  • January 2, 2025
  • 116 views
Not tech savvy. Purchased a G20 at the recommendation of Best Buy for gaming. I have a 600mbps plan. I'm only getting 6 download and 1 upload after swapping my previous router-modem. Talked to ISP and they're not sure. Is there a setting I need to change? I didn't see one on the website for the modem-router. Any help would be appreciated. Thanks.
Since you are experiencing slow Wi-Fi speed, I would suggest changing the Wi-Fi channels and monitoring the performance for 24 hours.
http://arris.force.com/consumers/articles/General_FAQs/G18-G20-Changing-the-Wi-Fi-Channel
Since you are experiencing slow speed on G20, is it through a wired or wireless connection?
Only with specific devices or all the devices are affected?
  • January 3, 2025
It is wired with a coaxial cable. It is through all the devices. On both 2.4 and 5.
  • 2295 replies
  • January 4, 2025
got a copy of the cable connections page and event logs? if wired and wireless are slow, then you need to start back at basic and check the connections
