2.4 ghz wifi very slow. Was fast
I have a G34 that for some unknown reason is having a problem with 2.4 Ghz band. I ran a speed test yesterday and my download speed is is 5 Mbps !  My 5 Ghz speeds are over 400 Mbps.  I have tried different channels to no avail. Speed remains the same.  Router is 1 month old and is on Comcast. A This problem started 2 days ago.  Any ideas on what happened?
Hello DrCorvette,
As you had mentioned that you are facing issues on connecting the 2.4GHz and also tried different WiFi channels .
Try following the below link
Let us know if this helps .
Hello DrCorvette,
  • 2275 replies
  • July 9, 2023
Have you tried testing its speed with a different device? Maybe its a device specific issue
  • July 10, 2023
It does seem to device related. I just tested my S21 and my Lenovo tablet.
Results: S21 3.58 Mbps upload  9.48 Upload
Lenovo  27 download and 14.9 upload
S21 test with my old Netgear router  45 download and 19.2 upload.
It seem my new Arris doesn’t like the S21.🤔
