Arris G-36 WiFi software for 2.4 Ghz?
  • August 23, 2024
  • 74 views
Toda
The Many
I’m having an issue with my “other devices” … that operate on 2.4-Ghz.  I purchased a WiFi repeater to enhance radio signals and nothing works. My Gateway Software isn’t there? Pasted Screen Text on my Surfboard says:
System Software Version
Software Image Name: { Edit: personal information}
Firmware Version: { Edit: personal information}
RDK-B-LLC:rdkb-20200207
SDK:N/A
Wi-Fi Driver:N/A
 Can anyone point me in the right direction to download the WiFi software?
Thanks in advance
» We will not have any software version for particular network but only you can see the device software version on the login page of your modem GUI
» Even the customers cannot downloads any Wi-Fi software manually.
» Could you please help me with the model of your Extender that you are using?
Toda
The Many
  • August 28, 2024
Thank you for replying to my message. The issue seems to be there isn't a Wifi software since on the first page, no WiFi software is detected.
 The extender I'm using is:
https://www.amazon.com/your-orders/pop?ref=ppx_yo2dv_mob_b_pop__fp_2_pp&orderId=114-4715548-6325035&lineItemId=jgoiouoltpotvops&shipmentId=GvnjKscfx&packageId=1&asin=B0D6RJK1JQ
The extender will only transmit radio 5-Ghz. The manufacturer seems to not have a solution for the problem.
