G34 wont let Blink cameras connect
  • October 7, 2024
  • 75 views
We just upgraded to an Arris G34 modem/router and now our Blink camera system won't connect. Keeps saying the password is wrong but it is 100% right. Ideas?
Since all other devices are connected and working with Wi-Fi, I would suggest entering the password without space on Blink camera.
Are you using the default Wi-Fi password mentioned on the modem label or the password which you have created?
  • October 22, 2024
As an update,  a hard reset is required on the Blink Sync Module in order to connect.
