W31 remote management
  • 19 January 2024
  • 72 views
Should I be able to change port  forwarding and such from out side my LAN.  It says I’m connected, can go in and edit items, but when I save them it’s not updating them.   And why oh why can I no just connect to a web page to be able to manage my router like 99.9% of every other router out there?
Outside LAN changing router configuration or port forwarding is not possible and when you are inside the network is not saving or outside the network is not saving?
Outside…  So why even connect outside the network if you cannot make changes?
And I’m sure there is no way to set up a DMZ for one IP address is there?  Wanting to set up a few game servers and would be easier just to open this computer up to all ports and handle security on it.     Like I said, my mistake for not doing more research that’s for sure.. That was a waste of lots of money for something so limited.. Guess that’s why amazon has them for $250 now..   oh well..
Outside LAN changing router configuration or port forwarding is not possible.
You can set up only through inside the network .
