Arris DG9459 question
  • 2 October 2022
  • 55 views
I’m just wondering what chipset this modem is using. I’m guessing it is Broadcom but I can’t seem to find any information online about the chipset.
edit: I meant to say Arris DG9450 sorry if this caused confusion
Thank you.
Best answer by SURFboard Moderator 13 October 2022, 17:42
Hello Castiel
Thank you very much for bringing this to our attention. I did some research and as you mentioned there’s no much information about it online. I’ll do some more deeper research to check if we have more information. I will follow up with you once I get an answer.
Thank you, I would imagine the TG9452 would be the same chipset as well. However I don’t see a data sheet listed for that modem either.
Hello Castiel
I tried looking for this answer even in Google and I’m afraid there was no information about this. I think it could be the same one as that TG that you mentioned but I don’t want to provide any wrong information or even create false expectations about it.
