connecting x5042 extender to Xfinity router using wps
  • February 13, 2024
  • 338 views
I'm trying to connect x5042 extender to xfinity wifi router to extend my wifi range. It gets connected through ethernet cable but the wps connection fails to setup. Any help is appreciated.
I found the manual at the FCC’s website.
Did you follow the instructions?
X5042 WiFi extender User Manual Mesh Extender Quick Start Guide ARRIS (fccid.io)
And what xfinity router are you connected to?
  • 2275 replies
  • February 13, 2024
