Answer
How can I update my firmware on my DOCSIS modem?
  • September 22, 2022
  • 809 views
How can I update the firmware on my modem?
You can’t. A modem only devices firmware is part of the provisioning from the ISP. Its pushed from them when they connect it to their system. And sometimes different ISP’s even have different firmware versions they’re on.
Its part of the docsis spec that it comes from the ISP.
Is there a reason you think it needs updating?
  • September 23, 2022
I want to ensure that my device is up to date to ensure that I am optimizing its performance.
The modem’s performance isn’t going to be based on the firmware. Usually firmware pushes fix vulnerabilities or security issues on modems. The modem performance is set by the provisioning your ISP pushes to it.
Are you having an issue with it?
Yes.  I experience frequent buffering issues.  Especially during video conferencing.  Do you have any tips on how to minimize that?
Hello Guerrera
Which modem do you have? there’s some information that we can check to see if there’s an issue with the signal or if something else is affecting the device.
