How to get shell access into a 3800HGV-B Router
  • September 21, 2022
  • 25 views
Folks,
I was wondering, is there any way to get shell access into a 3801HGV-B router?
We have a 3801HGV-B in our household and it has started to malfunction a little, with devices disconnecting from the network at random times. I was thinking perhaps I could access a shell inside of it so that I can troubleshoot it myself. Does anyone know how to accomplish this? See the attached image for more information about the system.
Router System Information
Hello watcher00090
I was not sure about this model number and after doing some research, I found out that the manufacturer for this device is 2wire. I strongly recommend to get in contact with them to check if this is possible and if this was leased by AT&T, it’s also a good idea to check it out with them.
Hope this information helps.
Hello watcher00090
