MOCA on SVG2482AC Modem
  • January 24, 2025
  • 25 views
How do I activate MOCA on my Arris SVG2482AC modem ? On the back it does signifies MOCA
  • January 24, 2025
the forums have different information. Some say the isp has to enable it (see link), others that you can turn it on through the settings, and others that it just works by adding a compatible adapter.
‎How to enable MoCa on Aaris SVG2482AC Modem/router? | Xfinity Community Forum
I don’t have one so I can’t test it.
  • January 24, 2025
Thanks...I checked the panels when I logged into my router but couldn't find it anywhere...I’ll give comcast a call and see what they say..I do own my router which I purchased. Been checking on how to use Moca Adapters..If I can get comcast to enable this feature then I would ONLY need one. We will see..
  • January 25, 2025
if you’re investing in moca, might be worth the little extra for a pair versus one. then if one works with the modem, you have a spare for elsewhere. Plus if it doesn’t, then you have the pair of them.
I’ve seen the 2.5gig moca adapters used and they’re pretty darned fast.
  • January 25, 2025
Thanks
