No internet
  • March 8, 2025
  • 118 views
Modem does not appear to be powered up.  No lights on modem.  No internet. Last night we had some power outages.   Could that have caused the problem?
What do I do?
Any help appreciated,
Rich Markovich
Could you let us know the product model number?
Since there are no lights on the modem, I would suggest checking the modem/router on a different outlet and power cord.
Also, try resetting the modem by holding the reset button for 30 seconds to check any changes on the modem/router’s behavior.
If you tried all the possible troubleshooting steps, I would suggest visiting www.arris.com/consumersupport for further assistance.
  • March 9, 2025
Could not get WiFi.  Modem/ router was not working.  You suggested hit the reset button or try another outlet.  Found out the outlet is blown.  Plugged modem into a different outlet and success
thank you so much
Rich Markovich
