SMS via WiFI doesn't work with S33 Modem
I have Xfinity Internet with mobile.
S33 Modem with Asus ZenWiFi AX6600 mesh routers (3 ea).
I think around the time I installed this setup from the Xfinity modem/router setup, I lost the ability to send and receive text messages with pictures via SMS.
Don’t know how to find that ability to correct that.
Any suggestions would be appreciated.
Its not going to be the modem. the modem doesn’t do any blocking. I’d check with Asus’s forums on if they have any settings that could be changed to allow it
  • 2295 replies
  • January 24, 2024
  • January 24, 2024
Thanks. I didn’t think so but just wanted validation.
  • 2295 replies
  • January 24, 2024
Good luck with it!
