User ID & PW No longer work How to Recover for S33 Modem and reset
  • August 31, 2024
  • 124 views
The User ID & PW I set some years ago for my S33 Modom don't work anymore, so how can I recover and/or reset again from factory? Will this affect my registration with my cable company if I safely reset using reset button? Thanks.
Best answer by Netopia
You’ll have to perform a factory reset using the reset button and it will not affect your registration with the cable company.
Forum|alt.badge.img+30
  • Rockstar!
  • 274 replies
  • September 1, 2024
  • September 1, 2024
I’ll try it, and Thank you very much for your help.
RK
