Hello,
After much back & forth with xfinity, they are telling me that the S33 is NOT mid split ready. Currently xfinity forces you to sub to xficomplete and use their XB7 or XB8 modem.
Xfinity customer support:
Cable modems need to be able to have the features to access the greater mid-split upstream bandwidth, and not all cable modems have that ability right now(Only our gateways). A modem will need to at least support DOCSIS 3.1. In other words, Retail modems do not yet support the new allocation. As this upgrade rolls out to more of our network in 2023, we anticipate the retail modem manufacturers will add mid-split to their modems and once they do so, you should then have retail device options available for higher upload.
Any firmware needed to be compatible is built and approved by Arris. They are the ones you want to ask about compatibility and when they will add the feature/turn it on.
My modem goes through several diplexer options on boot and is software ver TB01.03.001.10_012022_212.S3
My question is, does the S33 come ready for Mid-split upstream out of the box, or is this in fact a feature Arris needs to add via firmware.
I think xfinity is gatekeeping the mid-split feature to make more $$ off subs.
