wifi calling sb8200
  • June 28, 2023
  • 69 views
How can I improve my wifi calling?
Hello frankmundo
                             SB8200 is just a cable modem, so you will be using separate router connected to the modem to access Wi-Fi.
                              To improve Wi-Fi calling you need to have better Wi-Fi signal from the router so, to check and adjust the Wi-Fi signal, you need to access router interface/GUI.
                              For changing or correcting Wi-Fi channels you can contact the router manufacturer or login to the router GUI.
Hello frankmundo
  • June 30, 2023
Okay I use an Orbi system throughout the house. I will call Netgear then and see if they can help me. Thank you
