connection for AT&T mobile device with SBG10
I am trying to connect my Surfboard SBG10 to my AT&T Netgear mobile device
To connect SBG10 with the Net Gear router, I suggest enabling the bridge mode on SBG10 to avoid Wi-Fi interference.
http://arris.force.com/consumers/articles/General_FAQs/SBG10-Bridge-Mode-Setup
After enabling bridge mode, connect the modem to the router through an Ethernet cable.
To check on this could you please help us with the model number of the AT&T Netgear mobile device.
  • May 22, 2024
The Arris Surfboard SBG10
The Neatgear MR6110
  • May 23, 2024
Hello I have been trying to open the modem GUI from several computers but it won’t open up.
We understand that you are trying to access the GUI from different devices, still unable to login.
Let's try with a Reset and if still not able to access do update us with the error message so it will be easy to understand the issue.
Check the below link to do a Reset:
http://arris.force.com/consumers/articles/General_FAQs/SBG10-Factory-Reset
