Password for guest WiFi in SBG10
  • April 28, 2025
  • 66 views
I can’t setup a password for the guest WiFi in order to setup the Ring camera. On the ARRIS SBG10 doesn’t give me the option
It is not required for you to set up the Ring camera on the guest network; you can connect it to the 2.4GHz main network.
But if you have to setup a guest network, please find the below link to setup the guest network in the SBG10
http://arris.force.com/consumers/articles/knowledge/SBG10-Guest-Wi-Fi-Network-Setup
