SBG10 Port Forwarding
  • March 11, 2023
  • 147 views
I follow the manual to the T and still I can not get a port open with port forwarding or DMZ please help
Hello Tomtom
                        We understand that you are trying to do port forwarding on the modem interface, since you have done with all steps mentioned on the modem settings we would suggest you to restart the modem for a minute then try the steps mention on the link below and also make sure that the port number which you need to open are available or not using the port checker it make sure that the port is available to open.
                          http://arris.force.com/consumers/articles/General_FAQs/SBG10-Port-Forwarding-Setup
Let us know if this helps.
