I need to disable the wifi on my SBG8300 but I still want to be able to use all the ports. How can I disable the wifi without having to put it in bridgemode?
Is there another way to disable WiFi without having to put my cable/mode in bridgmode?
Best answer by JDub1025
I believe you can just turn off the WiFi radios under Gateway, Connection, WiFi, see screenshot.
