I have multiple computers that all need the same internal port number exposed on separate external ports (example : router:1001 → hostA: 443, router:1002 → hostB:443)
I reported your Port Forwarding setup internally. While we’re waiting their update, I suggest setting up Port Forwarding in the SURFboard Central (SBC) app. When you’re pairing the SBC app with your SBG8300, select the bottom link “Click here if you have previously installed with Web based UI portal”.
I will be able to assist on this forum. Please provide the SBG8300 firmware version, the browser name and version, and screenshot of the port forwarding setup you’re trying to setup.
I understand what’s going on with your Port Forwarding setup. When you select from the Common Service, the port is selected. If you like to specify the external port and internal port, select Other for Common Service.
I was using a test unit on my desk. I updated my comment with the image from our FAQ. I’ll need to report this to our internal team. In the mean time, setup the rule by selecting Other for Common Service and save the rule. Then try editing that rule to see if the external port fields appear.
I had tried that early on; it did not work either.
I have since reverted back to my previous modem/router because of this problem and lack of NAT loopback and returned the device from where I purchased it.
My next venture will be with an Arris S33 modem + Netgate router. I’m hoping that combination will work better.
Thanks for sharing the result with the port forwarding setup in the app. I’m sorry that the SBG8300 didn’t work out for you. I’ll provide an update on this post for the Community.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
